| Message |
I have no resolution on my accident yet. But I'm still looking at options of what I want to do. I'm definitely not fixing it, because the estimate I got was a little over $16K. That was a real, up on the lift, looking around estimate. One of the things I'm considering is a car with a spun bearing. Great chassis, interior etc, body is in good shape from what I've heard also. The car has (and here's where I need the help): Ported and Polished Exhaust Manifolds Ported & Polished Heads w/5 Angle Valve Job w/JWT Race Cams,JUN Adjustable Cam Gears, JUN Heavy Duty Valve Springs,JUN Titanium Valve Spring Retainers,JUN Bronze Valve Guides The car also has DSP Racing Super T28's turbos. The motor was built by SGP, and the owner had brought it back 3 times to have it rebuilt (bottom end issues each time, rod knock). Would I be better off: A) Rebuilding the motor in his car. B) Pulling the heads off his car, rebuilding my bottom end (nothing crazy, just a solid rebuild), and making a new motor from the two. The motor never made it past break in, the whole build, including turbos, has less than 2000 miles on it. The car is a 92. The car has also been sitting for a couple of years. What should I look for with the engine sitting for so long? Valve fatigue, turbo shaft play? Thanks to all for your input. ... Except Kenny
"...Downpipes own. They own everything...anything...all there ever was and will be...they should be stock on all cars. Screw the environment, emissions, noise! I love them...I shall name my first-born after them with glee..." - SeedyRom 05:13:20 10/03/02 "i love the cock" - genic 22:20:47 09/25/03 "I hope you get fucked in the ass with a pringles can." - ni[X]it 14:53:53 02/02/06 "Either ignore him or beat him up. Anything else will be over his head." - Marshall 12:28:23 08/18/04 z32baby: yeah, my memory sucks balls DJ Juiced: What's your memory doing this friday night? ;) "i've got to the point where i can drive the Z at its limits and i want more" - shadowZ 16:29:56 08/31/04 "I was way more timid then than I am now about getting in there and yanking on things." - TT XTZ 13:30:34 07/25/05
